Hi. Was very happy to see that surface support came recently and even more when i saw it was importable through landXML.
Since you now have surface as landXML i hope there is a small and easy thing for you to also be able to read point/lines as well ? LandXML is widely used here in my region!
Add me as a +2. Florida DOT provides alignment files (stationing) in LandXML. Would be nice if we could load that into Emlid Flow to be able to add Station/Offset to our measurements. As it is, I can only do this with third party software such as X-PAD with the road module.
Following up on this, I converted the dgn alignments to dxf and imported to Flow 360, however it does not come in in a useable format. The points are numbered randomly and only straight lines came in, none of the curves are present. I don’t know how I could use this for station/offset.
I will also add yours as +1 for surface landXML points and lines.
We currently support points and lines for the DXF format, but I will also note for your feedback to include arches and curves.
If you don’t need the arches and curves, additional preparation on the CAD software side can fix this. You can remove or hide layers with additional geometry (arcs and curves) so they won’t show up as multiple bunches of short lines and segments.
For this one, the codes and geometry could be on separate layers. You can adjust and merge them into a single layer before importing it.
Could you share the landXML points and lines and the DXF file? If you want to share it privately, you can send it to support@emlid.com and mention this thread.
While we haven’t directly supported curves and arches, I wanted to share an exciting update that might help streamline your workflow!
We’ve just released a new feature in Emlid Flow360 that allows you to import CAD drawings in DXF format. At the moment, curves will be automatically converted into polylines. You can also use this feature to stake out both lines and polygons. I’m including a guide with more details on how to use it.
Let me know if this fits into your workflow or if you have any questions!
