pi@navio:~ $ sudo usb_modeswitch -v 0x1bbb -p 0xf000 -c /usr/share/usb_modeswitc h/1bbb:f000
Look for target devices …
No devices in target mode or class found
Look for default devices …
product ID matched
Found devices in default mode (1)
Access device 004 on bus 001
Current configuration number is 1
Use interface number 0
Use endpoints 0x01 (out) and 0x81 (in)
USB description data (for identification)
Manufacturer: Alcatel
Product: MobileBroadBand
Serial No.: 0123456789ABCDEF
Looking for active driver …
OK, driver detached
Set up interface 0
Use endpoint 0x01 for message sending …
Trying to send message 1 to endpoint 0x01 …
OK, message successfully sent
Reset response endpoint 0x81
Reset message endpoint 0x01
→ Run lsusb to note any changes. Bye!
pi@navio:~ $
Message from syslogd@navio at Jul 18 11:32:55 …
kernel:[ 70.532673] Internal error: Oops: 5 [#1] PREEMPT SMP ARM
kernel:[ 70.545815] Process systemd-udevd (pid: 785, stack limit = 0xb47fe210 )
kernel:[ 70.546601] Stack: (0xb47ffba8 to 0xb4800000)
kernel:[ 70.547391] fba0: b5801c00 00000000 00000000 000000 00 00000000 00000000
kernel:[ 70.548977] fbc0: 00000000 00000000 00000000 00000000 00000000 000000 00 00000000 00000000
kernel:[ 70.550561] fbe0: 00000000 00000000 b3ab9440 b3aba000 809bd2d8 b3ab90 00 b53db000 804057a0
kernel:[ 70.552159] fc00: b47ffc5c b47ffc10 7f23f458 7f239120 b47ffc54 b47ffc 20 804c5ca4 8032eda8
kernel:[ 70.553802] fc20: 00000000 00000000 b0334c80 b02d9c68 7f240008 b3ab90 00 b3ab9440 809bd2d8
kernel:[ 70.555518] fc40: b53db000 00000000 804057a0 7f23fde4 b47ffc6c b47ffc 60 7f23f7ec 7f23f40c
kernel:[ 70.557293] fc60: b47ffcbc b47ffc70 80405e64 7f23f7dc b47ffc94 804140 28 b47ffca4 b47ffc88
kernel:[ 70.559136] fc80: b02d9c00 b2e06508 b02d9c68 b3ab9574 b02d9c00 b53db0 20 b02d9c68 b02d9c00
kernel:[ 70.561062] fca0: 7f2400a4 b53db000 7f23fd68 00000000 b47ffcec b47ffc c0 80414220 80405c24
kernel:[ 70.563032] fcc0: 80414138 8099c838 b53db020 00000000 7f2400a4 000000 1a 7f240100 b0312988
kernel:[ 70.565043] fce0: b47ffd14 b47ffcf0 803aeddc 80414144 b53db020 7f2400 a4 b53db054 00000000
kernel:[ 70.567086] fd00: 7f240008 7f240100 b47ffd34 b47ffd18 803aef68 803aec 20 00000000 7f2400a4
kernel:[ 70.569139] fd20: 803aeec0 00000000 b47ffd5c b47ffd38 803acfac 803aee cc b59ee35c b52204b4
kernel:[ 70.571191] fd40: 805f12e8 7f2400a4 b0395e80 808ec168 b47ffd6c b47ffd 60 803ae730 803acf40
kernel:[ 70.573243] fd60: b47ffd94 b47ffd70 803ae378 803ae710 7f240008 b47ffd 80 7f2400a4 00000000
kernel:[ 70.575295] fd80: 808ec168 7f2400a4 b47ffdac b47ffd98 803af568 803ae1 d0 7f240070 00000000
kernel:[ 70.577346] fda0: b47ffdd4 b47ffdb0 80413b98 803af4ec 808a2398 7f2420 00 808a2398 b0312a80
kernel:[ 70.579397] fdc0: 00000000 7f240100 b47ffde4 b47ffdd8 7f242028 80413b 24 b47ffe5c b47ffde8
kernel:[ 70.581450] fde0: 800097a4 7f24200c b0396880 b5801f00 b47fe000 8089c8 20 b5801f00 b47ffe20
kernel:[ 70.583503] fe00: b47ffe1c b47ffe10 8034239c 8014ab10 b47ffe5c b47ffe 20 8014ab10 8004a7d4
kernel:[ 70.585555] fe20: 7f240100 00000004 800fed30 024000c0 00000001 7f2401 00 00000001 7f240100
kernel:[ 70.587609] fe40: 00000001 b0312a40 7f240148 00000001 b47ffe84 b47ffe 60 800fed6c 80009710
kernel:[ 70.589661] fe60: b47ffe84 b47ffe70 8013c158 b47fff44 00000001 b03129 80 b47fff3c b47ffe88
kernel:[ 70.591713] fe80: 8009f340 800fed04 7f24010c 00007fff 7f240100 8009c7 04 80160748 805f8478
kernel:[ 70.593767] fea0: 00000000 7f24010c b80d6c64 7f2402e4 8089e57c 7f2403 00 805f8494 b47fff44
kernel:[ 70.595820] fec0: 7f23fe4e 00000001 00020b30 00000000 0b300002 000000 00 00000000 7f23fb18
kernel:[ 70.597874] fee0: 00000006 00000000 00000000 00000000 00000000 000000 00 00000000 00000000
kernel:[ 70.599927] ff00: 00000000 00000000 00000000 00000000 00000020 000000 00 00000008 76db1004
kernel:[ 70.601980] ff20: 0000017b 8000fd68 b47fe000 00000000 b47fffa4 b47fff 40 8009fc78 8009d80c
kernel:[ 70.604033] ff40: 00000002 b80d3000 00003cb4 b80d664c b80d4e9f b80d5a 48 00001300 000013d0
kernel:[ 70.606089] ff60: 00000000 00000000 00000000 000010e8 00000027 000000 28 0000001f 0000001c
kernel:[ 70.608144] ff80: 00000017 00000000 00000000 21136800 00000000 000000 00 00000000 b47fffa8
kernel:[ 70.610198] ffa0: 8000fba0 8009fbf4 21136800 00000000 00000008 76db10 04 00000000 76db1928
kernel:[ 70.612254] ffc0: 21136800 00000000 00000000 0000017b 76db1004 000200 00 5662afd8 00000000
kernel:[ 70.614309] ffe0: 7ee9e1f0 7ee9e1e0 76da909c 76f05d40 60000010 000000 08 00000000 00000000
kernel:[ 70.651350] Code: e5843098 e5841094 e584209c e5940000 (e5d31003)
