JST-GH 7p-7p
I’m currently working with a Reach RS2 base and a rover kit.
The base is serving as a stable gps to provide RTK correction to the rover using LoRa.
Problem is: the 7p-7p cable connector (this one) broke. I’m trying to buy another one, but it seems really difficult to get the correct connector/cable model. Is there a safe and relatively cheap way to buy a new one?
thanks in advance.
Thanks for the response. I searched in the emlid store but i managed to find only the 6p-6p cable, not the 7p-7p required to connect the lora receiver the rover. Am i missing something?
My fault, you’re using the s2 port for LORA ? I’m understanding that the cable they have would work ? I don’t know. I’d contact Emlids directly they will help you. My M2 s2 does indeed have 7 pins. There’s a danger supplying power to both the USB and s1 ports.
I don’t have mine with me right now but contact them via email, they are very responsive.
yeah, i’m referring to this image
the cable broke, and i don’t know if there are other methods to connect the lora receiver to the rover
I pm @inkar.madikyzy with Emlids. You should see a response soon
thank you
Hi @enricocovili,
Welcome to the forum!
Some spare parts, like cables, are usually easier to purchase from local stores. That’s why we don’t provide them in our store.
Here are the specs:
  • For the cable, we use a 1.25 mm pitch JST-GH 7pin connector.
  • M2 S2 port is SM07B-GHS-TB, and its corresponding connector is GHR-07V-S.
Thank you for kind response.
This were all the information i needed.
I think I found some at eBay, 6 cables for $15
Here’s some at Amazon
https://www.google.com/url?sa=t&source=web&rct=j&opi=89978449&url=https://www.amazon.com/1-25mm-Connector-GH1-25-Replace-JSTA1257/dp/B0D9HHZQ7P&ved=2ahUKEwj-ytO7y6qLAxXC5MkDHa0BCBYQFnoECBEQAQ&usg=AOvVaw0BiDy0lRRrjRBuEJDWZK9M
