Hello everyone,
I have recently updated both of my Reach RS+ receivers to latest dev update. What i want to share as an issue is that when i connected to my NTRIP caster, i could not select any of the mounting points from the drop down list. I saw there is an edit icon next to the list, but all it did is to create a custom name.
I just wanted to share this with you, and ask if i need to roll back to previous version say 2.16 which was stable, can i do that?
You cam downgrade by using the manual image found on the webpage, and then follow the instructions for manual update.
But have you tried the new 2.17.2 image?
If i can make a suggestion for future updates in the software, i would like to see a stake out option for a line, for example if you have point 1 and point 2 with distance between them 200m, and you want to divide this distance in smaller distances lets say 50 m. if ReachView is capable of doing that, it will be great.
