Hi…I have had a ton of issues with my Navio2 board. Fundamentally arbitrary stops inflight. When taking a gander at the logs there is no unmistakable blunder simply an unexpected end of information. Annihilated 3 copters and a quadplane with this framework and Emlid can never appear to help following the wellspring of this issue. Same outcome on 2 distinct sheets and 2 unique Raspebrry pi’s
Hi Lilli,
We’re always here to help you in finding the causes of unexpected behavior. However, as long as there’re few details on the issue, I can hardly make any conclusions on the case. Please, provide the following information so that we can work this out together:
- Navio2 Image and ArduPilot version.
- Detailed issue description. What exact conclusions made via the flight logs so far?
- Picture of the setup and connection scheme.
- Exact make and model of additional hardware.
At the moment, my first assumption was that there’s an unstable power supplied to Navio2 and the drone’s parts. I recommend checking your battery as it could be a source of the issue.
