I have one of you Navio board and yesterday compiled the ArduPlane on the raspberry pi itself using your instructions. However when I try to run it I get the following error message
pi@anra-raspi ~/ardupilot/ArduPlane $ sudo ./ArduPlane.elf -A udp:192.168.1.11:14550
sh: 1: pigpiod: not found
sh: 1: pigs: not found
No pigpio interface for RCInput
I got it working fine and when I connect using APM Planner I can get the telemetry data but mission planner does not work. Any suggestions on how to fix that
Any ideas in what is going on. Further to my previous response. Yes I have the latest mission planner. ArduPlane fails to start on raspi using tcp. It only starts using udp so I haven’t been able to test using tcp
Misson Planner is known to have issues with UDP\TCP connections, in the latest version it should’ve been fixed, but sometimes the issue arises again.
Could you please provide a command you use to run APM with TCP?
I just tried to connect to Mission Planner over UDP and it worked without a problem.
Mission Planner was downloaded from here - http://ardupilot.com/downloads/?did=82
I selected UDP as a connection type, clicked “Connect”, entered the “Port” and pressed “OK”. It connected immediately. Ardupilot was running with the following options:
sudo ./ArduPlane.elf -A udp:192.168.1.46:14550
Are steps you do any different?
Also, why do you prefer to use Mission Planner and not APM Planner?
