reach1
(Tjr)
December 23, 2018, 2:59am
1
Hope I am doing something wrong.
Running v2.16.1 on Reach RS
Got the LoRa receiver for M+ and trying to get that to work together.
On the RS HTML interface I keep getting this red bar saying “LoRa is not connected”.
The Apply button is disabled keeping me from saving any settings.
TB_RTK
December 23, 2018, 9:13am
2
There are couple of things you can try.
1.Make sure LoRa is not enabled under any other settings.
2.I assume the antenna is plugged into M+ ?
3.Reflash the unit
reach1
(Tjr)
December 23, 2018, 6:46pm
3
Am getting this message on the RS side, where LoRa is built-in.
The antennas are connected to both RS and M+ LoRa unit.
On the RS, LoRA is enabled only in the ‘Base Mode’.
On M+ it is setup for the ‘Correction Input’.
timd1971
(Timd1971)
December 23, 2018, 8:35pm
4
Are your LoRa settings identical in each the RS and M+?
TB_RTK
December 23, 2018, 9:36pm
5
If you get this error on RS, the one you use as base. The LoRa output is set under base mode. That is what you have done, right?
reach1
(Tjr)
December 23, 2018, 10:06pm
6
Settings are identical on both.
RS:
M+:
Seems I got the link to work now (grey bars on the M+!), but the error message remains on the RS:
bide
December 24, 2018, 2:39am
7
Go into the settings (gear icon), and click “Reset settings to default”.
If that doesn’t work, then do what @TB_RTK said:
Hi @reach1 ,
How is it going? Did the reflashing help?
reach1
(Tjr)
January 12, 2019, 6:50am
10
No, it did not help. After reflashing upgraded to v2.16.2 too.
Keeping getting this red bar “LoRa is not connected” on my Reach-RS action as base.
But the rover is getting corrections over the LoRa link ok, so the radio seems to be working.
bide
January 12, 2019, 7:04am
11
At least the radio is working for you!
But it is very strange that you are still getting the error message.
Hi @alfredodelellis ,
I’ve just replied to you in the email.
Bunog
February 6, 2019, 9:24am
14
I am also having this problem in my base. V2.16.2
Hey there,
The issue with “LoRa is not connected” message was fixed in v2.17.2 dev release:
Hey everybody,
It’s been a while since we rolled out an update! We are currently busy improving the platform layer, updating internal stuff. So today we are pushing a new dev update with several big improvements under the hood which will also improve the experience with Reach.
Fixes
Fixed LoRa is not connected message popping up on some RS and RS+ receivers.
Fixed Android app not being able to download logs or projects. Please note that you need to update both the app in the play market and …
system
(system)
Closed
June 12, 2019, 1:35pm
17
