Hello there!
According to its datasheet, it can only be connected by UART or CAN interfaces.
Maybe something like LIDAR-Lite can do the trick.
Is there can connection in navio2?
I’m not sure, actually… There is not, as far as I can see.
I would suggest you use some sort of SPI - CAN transceiver, but it looks like SPI is also already used too, unfortunately.
ok, but using UART it’s should work without any problem?
