Hello,
I found a product called “FrSky Smart Port to UART converter” and I’m wondering if it is compatible with Navio UART input. The aim would be to read telemetry information from Taranis+ OpenTx.
Link :
http://www.t9hobbysport.com/frsky-s.port-to-uart-converter-with-2-adc-ports
This product is initially designed to be used with two units : A (connected to receiver) and B (connected to emitter).
I feel like it is not compatible, otherwise it may appear here : http://copter.ardupilot.com/wiki/common-frsky-telemetry/#apm_mavlink_to_frsky_smartport_converter_mavlink_frskysport
Thank you
I think this might be interesting for you:
Hey
At Airborne Projects we have developed a APM MavLink to FrSky SmartPort Converter based on the Arduino Nano, designed and tested with the Navio in mind, allowing for connection through the USB port of the Raspberry PI.
We initially designed it for ourselves because the alternative, as also mentioned on this forum Telemetry to FrSky receiver was a Teensy, which not only is not open source friendly but is also very expensive.
Our project features full compatibility with typical RC voltag…
Yes absolutely, I actually purchased the whole Airborne catalog
On the dedicated post , CodeChief mentions the ability to connect either with UART or USB, but I did not see UART was possible. I prefer light UART wires instead of USB, anyway it should work.
Thank you
0xCCD
(Christian Lallemand)
November 13, 2015, 10:14am
#4
Their is also a slightly cheaper way, but it requires some soldering
http://copter.ardupilot.com/wiki/common-frsky-telemetry/#x-receiver_setup
the already mentioned ‘ready to use’ cable is also mentioned on this page
Thank you for your reply, I now realize I was looking at the wrong device.
When I saw this other way, I was not sure it was compatible with Navio+.
