I want to know what is the best way to do this… I have a Huawei mobile hotspot attached to my quadcopter and a Nexxt usb wifi dongle. when I want to connect to my public ip it does not work…
Can you give me some advises to make this work.
**Sorry if I do not explain myself very well, english is not my first language… I you have doubt tell or do not understand tell me and I will do my best .
You really need to provide more details about how everything is set up and what does no work exactly. Including the commands that you run, outputs etc.
Hi @ivereninov, sorry for the understanding… I have my raspberry connected to internet through a mobile wifi hotspot… when I want to ping my pc (GSC) from the RPI it works, but when I want to connect to the mission planner via the port 14550 it does not work…
Hey @keithc that is what I thought… Because I can ping my pc from the raspberry pi,
But I don’t know what happened because I made an exception to the firewall to open that port…
What kind of times are you getting when you ping your VPN? I have a RPI connected via VPN, when i connect via wifi i get 3-5ms ping, but when im connected via 4g is more like 200-500ms but my speedtest is showing more than 20Mbps
I want to know if the VPN is somehow slowing down my conection
Hi @CavP28 I have a quick question. Did you install LogMeIn Hamachi on your raspberry pi using the commands from the LogMeIn Hamachi user manual? If so, did you use the installation commands for Ubuntu or CentOS to install LogMeIn Hamachi on your raspberry pi? Thank You.
