Internal Tests failed - Emlid M2
Hi all.
Here we are facing issue in Emlid M2 devices.
The issue is (Internal Tests Failed) So please suggest how to solve this issue.
I would suggest to reflash the firmware this way.
Hi there,
Reflashing can be a way to resolve the issue. However, we need a bit more detail on each case to determine the actual issue provoking this. That’s why it’s always a good idea to write to us at support@emlid.com if you happen to come across it.
In this case, we’re in touch with Rathod over the emails. We’ll continue to investigate it there as we may ask for some sensitive info that’s better to share in private.
