Hello Emlid community…
We are a helicopter company that has pushed into agriculture drones over the last year. We operate a small fleet of XAG P100 Pro drones and are integrating RTK our operations.
XAG offers an RTK solution but it’s really ineffective. It’s based solely on single point GPS signals and only one drone can be connected to each base. When running two or three drones at a time, this solution is awful. It’s inaccurate, offers very little connectivity, and costs as much as the Emlid Reach RS2+.
Recently, we added a WingtraOne to our fleet and several vendors recommended the Reach RS2+ as a possible solution to our issues so we purchased one and can immediately see huge benefits simply using it as a PPK base station for the Wingtra.
Unfortunately, the XAG software offers extremely limited options for getting RTK corrections. You can either connect to the XAG XRTK4 or a NTRIP network. My thought was to try to connect using the Emlid Caster solution. This seemed like it would be the answer we have been looking for.
However, while I can connect the XAG drones to a normal CORS/NTRIP network, the drones cannot connect to Emlid caster. I suspect that this is due to the required “Mount Points.” This is a setting that a normal NTRIP network would not require.
Being able to have our drones connect to our Reach RS2+ would be a huge step forward in safety and accuracy for our agricultural spray missions.
I searched through these forums and have found no mention of XAG drones at all. So I suspect I may be breaking new ground here.
Does anyone know if there is a method to connect via NTRIP using Emlid Caster without having the ability to enter the mount point?
I’m using the most up-to-date firmware and software for the Reach, Emlid Flow, and the XAG drones. Any suggestions that someone could offer would be very welcome. And if I find a solution, I will certainly post that in detail here for any future users that might be trying to solve the same problem. I’m a giant fan of the Emlid Reach and really hope that we can find a way to make it the PPK and RTK solutions for our agricultural mapping and spray missions. We operate multiple trucks each with multiple drones and I would like to scale this to all of them.
Thanks in advance for your time.
