Hey guys, I am trying to use survey software on my laptop with my Reach RS units. What I need is the software to access the raw data log files (every second). So it is not position output that I need. Is there a way to setup Reach RS so that I can connect my laptop to the Reach RS via BT and let the software read the Reach RS log files constantly (every second)??
I can connect my laptop to the Reach with no issues. But setting up the EZ Field software to access the log files has been unsuccessful. Any help will be appreciated.
If the EZ Field software can not communicate directly with the Emlid Reach RS, then it just needs to read the uBlox raw log files each second. So maybe there is a way to just map the log files so that EZ Field can read them?? Again, thanks for any help on this.
