Dear Friends,
I wanted to confirm, is it possible to integrate 2 units of M+ GNSS receivers with one Reach RS+ as base for RTK mode through LoRA?
Thank you
Dear Friends,
Thank you
Yep, that’s Works perfectly. You just need separate Lora radios for the m+’s
Hi Stan,
As Cristian said, it is indeed possible. All you need is to provide both M+ units with LoRa radio from our store and configure each rover according to this guide.
Also, you can send corrections from your base station to rovers via Emlid NTRIP caster. Keep in mind that this method will require an Internet connection on all three devices.
