Hello,
I used to run EDGE with a Windows ground station without problems, however now I switched to a linux and couldn’t follow to quick start guide.
When I try to install the WiFi driver with to command:
sudo ./install-rtl8812au
I got the following error message:
gabriel@gabriel-note:~/Downloads/edge/8812au$ sudo ./install-rtl8812au
[sudo] senha para gabriel:
EFI variables are not supported on this system
Building the module
make ARCH=x86_64 CROSS_COMPILE= -C /lib/modules/5.3.0-26-generic/build M=/home/gabriel/Downloads/edge/8812au modules
make[1]: Entering directory ‘/usr/src/linux-headers-5.3.0-26-generic’
CC [M] /home/gabriel/Downloads/edge/8812au/core/rtw_cmd.o
CC [M] /home/gabriel/Downloads/edge/8812au/core/rtw_security.o
CC [M] /home/gabriel/Downloads/edge/8812au/core/rtw_debug.o
CC [M] /home/gabriel/Downloads/edge/8812au/core/rtw_io.o
In file included from /home/gabriel/Downloads/edge/8812au/include/osdep_service.h:41,
from /home/gabriel/Downloads/edge/8812au/include/drv_types.h:32,
from /home/gabriel/Downloads/edge/8812au/core/rtw_io.c:52:
/home/gabriel/Downloads/edge/8812au/include/osdep_service_linux.h: In function ‘_init_timer’:
/home/gabriel/Downloads/edge/8812au/include/osdep_service_linux.h:277:8: error: ‘_timer’ {aka ‘struct timer_list’} has no member named ‘data’
277 | ptimer->data = (unsigned long)cntx;
from /home/gabriel/Downloads/edge/8812au/core/rtw_cmd.c:22:
