Hi
My task is to map forest tracks. accuracy should be around 0.5 to 1m. Of course a normal GPS will not work. So i ordered the reach kit. I have not received it but I am thinking how to improve.
As I will use it in the forest I have heard from some experts that this will be a hard task with “normal” antennas and RTK because of multi path problems.
The idea:
If I use booth reach GPS modules on a stick with 50cm known distance. I can use a averaging or something more sofisticated to get a better solution for the position. Theoretically a raw solution can be calculated with the knowledge that the 2 antennas are exactly 50cm away. I expect a more reliabel result with less multi path problems.
question:
Would this help?
Has anyone done something like this?
thank you and best regards
Franz
