Incorrect Pole Height Entered — How to Correct in Post-Processing on Emlid Reach 3
Hello,
I have an Emlid Reach 3 with the TILT function. The problem is that I carried out a survey with the pole set to 2.00 meters, but in the app I entered 3.50 meters. As a result, the points are incorrect. I would like to know if there is a way to correct the instrument height afterward (in post-processing) so that I can obtain the correct measurements.
Thank you
Can’t you just edit the Excel file? Change the column to correct the pole height and then math the elevation column to raise the values by 1.5 meters. Then just import them back into a new project. If you used a localization don’t forget to save it as a custom CRS and set the project that way before importing.
Is the elevation column the elevation RMS column? (The starting value is 3.904 meters while the set value was 2 meters)
I use a projected CRS so it is in “Elevation” column. If you are using a geodetic CRS then it would be the “Ellipsoidal height” column.
Micheal is correct just change in CSV file, there is no way to change it in emlid flow.
I’ve done it plenty of times jumping from Ute to pole. My tip is also once you’ve correct them in the CSV file id then delete all points from the project and re upload the corrected CSV file into the project again in emlid flow.
I nearly got caught out coming back to a project a year later and nearly forgot about the affected points. I originally fixed the points via Excel then uploaded the file into my program but left the raw data unchanged in the emlid flow project. Close one :grimacing:
Thank you for the answers, but I’m having major issues with the various formats. The first difficulty I encounter is importing the .csv file into Excel. It messes up the dots and commas. In fact, if you look at the height, it’s an integer and has no decimals. And the same happens when exporting…
@ivanporcu,
Is the tilt enabled when you collected these points? If so, we do not currently support post-processing CSV in Studio or Flow when tilt is enabled, as the tilt angles are not considered during processing, which can lead to inaccurate results.
Since the original vertical and horizontal positions were computed with tilt, simply adding or subtracting the pole difference will not give correct results.
I’ll raise this to the developers and add it as a feature request.
Thank you, I figured as much. I ran a test with a simplified text file, modifying only two points — the original one and the corrected one. The result is the same, and the points re-imported into the app completely overlap. This is because, as I assumed, the software exports the point in .csv format already processed. The data in the various columns are just a report, and nothing can be reprocessed from them.
Still, yes, it would be nice if an update were released regarding this — even just a warning message to check the pole height, or, even better, a dedicated screen for it. Because at the beginning of a survey, it’s easy to forget to set that value.
As I remember it, you have integer azimuth and tilt info in the Full CSV output. It would be fairly easy to let i.e. ChatGPT use this information to correct each point. Of course, there would error sources here, like how much did you move the rod during point collection, and the azimuth and tilt info being just integers.
But it will put your points with a few centimeters, which is far better that your current situation.
EDIT: hm, nop, only tilt values seem to be available. I was sure I have seen Azimuth info as well in the past?
@ivanporcu I understand. I’ll take note of your suggestions.
I tested it a while ago @wizprod . The heading angle is available. Perhaps you exported it and reimported it back to Flow? When you export it, only the tilt angle is in the CSV.
So I also just input the incorrect pole height (0) instead of 1.75 m. And was hoping to use the tilt angle and the azimuth to do some backwards trig/translations. But I wasn’t quite sure what the azimuth was measuring so I did some field tests and it turns out that the azimuth is truly just a direction it thinks its pointing in, NOT the direction of the tilt direction. So even if you were tilting north or south or east or west, the azimuth will only tell you which what the IMU or whatever is recording the azimuth was facing. Which means you cannot correct for the height this way. AND, it turns out that you need to figure out which way the azimuth recording device is facing - I took two points about 5 meters away from each other such that one point was due north of the other, and I had the receiver head oriented north/south, i.e., the power button was facing north/south, and the azimuth read ~30ish degrees. When i rotated it 90 degrees so i thought it was facing East/west, the azimuth read ~120 degrees, so it was consistent, but not to true north - basically you would have to do this test and physically mark on your receiver head which way it thinks is north.
I have some screenshots of the test and the csv output with the added azimuths (there are less points in the csv than the project because i removed some redundant points). the description code is as follows. We tried to describe which way the power button was facing (north (n) or east (e),) and then which way we tilted the pole, with a 0 being no tilt. A prefix of 0h means the pole height was set to 0.
All to say, the azimuth is misleading and not useful in trying to correct your data if you don’t do your own calibration test. I would love in the future if possible to get an azimuth that describes which way the pole/receiver is tilting.
Hope this helps someone!
@gs-g-mawhl_emlidflow
Thank you for that detailed analysis
boston
Hi @gs-g-mawhl_emlidflow ,
Thank you for your analysis. The azimuth from the CSV indeed is different from the variables needed for the calculation. I’ve brought this to the team’s attention. While we currently do not support the recalculation of coordinates when the pole height is wrong, we’re collecting such cases for consideration, and I’ve added yours as +1.
This is not currently on our roadmap, but if anything changes, I’ll let you know.
Any update on this?
Hi @hamish.sutton,
Welcome to our Community Forum!
I’ll go ahead and add your request as a +1 and share it with our developers. At the moment, this feature is not planned on our work radar, so I’m not able to provide an exact ETA just yet. That said, as soon as there’s any progress on this, I’ll be sure to update the thread right away.
