Incorrect cut value during stakeout with 33 Beta 1
I updated both of my RS3s yesterday to the 33.1 firmware. I went to a project that I had previously surveyed with the 32.X firmware and am having issues. When I “Stake Out” any of my previously measured points I see that horizontally I am right on the point, but vertically it says I have 2.134 m of cut. I am using a 2 m rod and I’m pretty sure that the sensor offset is .134 m. I have checked and rechecked that my antenna height is set at 2.134 m (rod + sensor offset). Is this an issue with the new 33.1 firmware? If so, how quickly can it be fixed? How do I roll back to a 32.X firmware version? Please help, and thank you.
Not sure if this thread helps any:
CUT-FILL incorrect (bugged) to linework/points (but surfaces correct) - Emlid Flow & Emlid Flow 360 / Survey tools - Emlid Community Forum
Hi @Dunning,
What version of Emlid Flow is installed on your device? Do you use an Android or iOS phone?
Could you please share the CSV and the stakeout report from Flow, along with the Full System Report from your device?
Since the data contains sensitive information, you can email it to us at support@emlid.com. Thanks!
