I have been working on the Navio2 exemples for one month and I’m still stuck at one point, concerning the UBLOX M8.
Indeed, I couldn’t manage to raise the frequency of the UBLOX to 10 Hz.
It seems that the issue is the GNSS configuration : by Default, the UBX module takes multiple GNSS constellation (GPS + Glonass + QZSS + … ) which restrain its max output frequency, thus it’s impossible to get data at 10 Hz.
The only way to have the data at 10 Hz is to change parameters on U-Center (via Utilities/ublox-to-tcp) , enabling only the GPS constellation (in CFG-GNSS) and disabling the others.
Unfortunately, The settings only stay for max a day, then reset automatically (due to spi-memory written on flash ??? ) . Maybe there is a way to fix UBX-CFG parameters easily in the ublox.cpp ?
I have tried to use the .configureSolutionRate function, but I couldn’t manage to improve the frequency with it (when displaying the GPS sample time).
Thank you,
Jean
