I would like to add to the requests being able to import not only points but also lines into reach view. either a custom map or as part of the point import would be great.
this would greatly help to stake out points, in my case on the construction site where a lot of points (even when labeled) are really confusing.
I’m very happy line stakeout is planned. thanks for the feedback.
With custom map I basically meant to being able to import a pdf file or image (maybe also geotiff) which could be use as a backdrop; simply to have a better overview of the project.
In my specific case, it would be great being able to have a floor plan as backdrop.
Depending on how line stakeout is implemented, a custom map feature is maybe not even necessary.
Thank you for your feature requests! We collect them and keep them in mind. However, since their implementation may take a long time and requires thorough research, I can’t tell you any time frames.
I also want to specify this. As far as I know, some softwares have points classes like survey points, stakeout points, calculated points, and so on. You can turn them on and off on the map for convenience. Do you mean this feature or feature codes for points?
