I’m sure this is something really simple, but I can’t seem to find the answer online…
I’m importing a DXF file into Emlid Flow, but I can’t figure out how to get the scale / unit of measure correct. The DXF is exported with a line at say 10,000mm long, but is showing in Emlid Flow as 10,000m long.
In other cad programs we work with we have the option of selecting the unit of measure for the import, but I can’t find how to do this in Emlid Flow.
I’m not sure how to do this sorry… I don’t seem to have any options presented to me inside Emlid Flow that give me that option - that I can see anyhow.
Or are you thinking that is an export function out of the CAD software?
We’ve done a bit of digging with the designers in this space, and they done this, but it seems to have lost the geo references in the export somehow…
It was coming in somewhat correctly, as in the starting coordinate was correct and then just the wrong scale from there.
Perhaps if you described your current workflow with a brief description of what you hope to achieve that would add some clarity and help us to arrive at a suitable recommendation
@Sudfelt, you can also share the data so we can help check it further. If you prefer to keep the data private, you can send it directly to support@emlid.com.
