using the RS2 to mark GCP’s, is there a way to import points or a boarder to be displayed on the map for situational awareness?
Hi @joel,
I agree with Zach. Now you can only convert your KML to CSV, SHP, or DXF with 3rd-party software and import points to ReachView 3. Regarding borderlines, you can’t import lines at the moment, but it’s on our roadmap!
Also, I’ll report to our devs about KML support.
This would be awesome. We like to plan GCPs in Google Earth and it would be great to translate that to the filed app. We aren’t trying to be extremely accurate in google earth we just want general areas that our field guys know where to go to set control and collect a point
Your request is noted. We’re working on adding satellite background map to the ReachView3, so stay tuned!
when exporting the survey in dxf format, only the number of the point and its height are exported… we need the description or a code to be exported to be able to know which points they are and do the cad drawing… and the satellite image of google maps or earth in the background, for location and reference while the survey is being carried out in the field… they are very useful things that are needed and would greatly help the work in the field. thanks and excellent work. Emlid is the best.
