When I import my points, it does not recognize nor register the point numbers as I have imported them. It just renumbers everything from 1,2,3,4,5,6,7,8,9,10,11…etc. For instance, I want a set of points to have pointnames/numbers to be between 200-399 series and another set of points to be between 400-599. When Emlid flow changes its numbers, it completely destroys my intentional numbering system.
What am I missing?
Hi @papa,
I get what you’re going for with the numbering. To help figure out what’s going on, could you please send the file via PM or support@emlid.com? Also, what format are you using? I’ll take a look!
Hi @papa,
Thanks for sharing the file! I’ve had a chance to take a look at it and replied to your email with some thoughts. When you have a moment, please check it out.
