We use Navio+ device for our project. We have 3DR GPS+Compass combo (https://store.3dr.com/products/3dr-gps-ublox-with-compass) and whenever we connect it to I2C port, the whole system acts strange: the props start spinning up without any arming right after power up (very dangerous), intermittently impossible to arm from RC remote, sometimes system just hangs. We actually only use the magnetometer part of the 3DR GPS+Compass, not using the GPS.
We also have an external status LED that connects to I2C port. When that LED is connected directly to I2C port it works, but when connected via an I2C splitter, it doesn’t work, even though with Pixhawk the same setup works.
It is important for us to use external magnetometer to avoid magnetic interference (we cannot relocate Navio+ much inside the case) and as of now we simply cannot make it work with Navio+.
I’ve looked at the output of i2cdetect while external magnetometer is connected and it is very strange: it shows some devices disappear intermittently and shows some other devices that are not even there.
Here’s the output of i2cdetect executed multiple times in the row with external magnetometer connected to I2C port:
pi@navio-rpi ~ $ sudo i2cdetect -y 1
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: 03 -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- UU -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- UU -- -- -- --
40: 40 -- -- -- -- -- -- -- 48 -- -- -- -- -- -- --
50: 50 -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
00: -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- UU -- -- 1e --
40: -- -- -- -- -- -- -- -- 48 -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- 77
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- 28 29 2a 2b 2c 2d 2e 2f
30: 30 31 32 33 34 35 36 37 38 39 3a UU 3c 3d 3e 3f
40: 40 41 42 43 44 45 46 47 48 49 4a 4b 4c 4d 4e 4f
50: 50 51 52 53 54 55 56 57 58 59 5a 5b 5c 5d -- --
pi@navio-rpi ~ $
So do we have a faulty Navio+ or is it incompatible with 3DR compass? Why does the system behave this way?
Thank you for your help!
