I’m having the same issue on my RS2 unit. My current firmware is 2.22.5.
Hey everyone,
We’re looking into the updating issues. I’ll post an update once there’s a fix.
Hey guys,
We’ve fixed the issues with the updating process. Now it should be possible to update your receivers without any complications.
Hi what’s the solution? Latest firmware update? ReachView app update? Thanks
Hi Juan,
You can update your receivers to the latest firmware version by clicking the Update ReachView button in the Settings tab of the ReachView app. The process is described detailedly in our Updater guide.
There’s no need to reflash your device with the Reach Firmware Flash Tool.
I’m having problems with updating from version 2.20.5 to 2.24.0. It fails every time.
Tried both from app and my browser.
If it continues to fail, then try the Firmware updater application instead.
Also, I might be that this intentional, as a previous firmware update (I can’t remember to number exactly) required to be done via the firmware updater, after which the normal firmware update routine (via the web interface) would work just fine.
Hi Andreas,
Please, reflash your Reach RS2. To do so, you can follow this guide. Please note that the reflashing procedure resets the settings and deletes the stored data.
