I am building a Autonomous Drone. I am completely new to navio and Raspberry pi 3. I have couple of question regarding this.
1)Since my project requirement is to go to particular GPS location provided. I have to write a python script that will do the job. I am kind of confused when I connect navio2 with raspberry pi 3 the interface of the raspberry pi goes away. So how I am supposed to write a python script.?
I have connected everything on my drone. My motors are not spinning. So I am assuming do I have to upload the code and after that it will start working.
Why don’t you want to write a script on your laptop/PC and then transfer it to RPi?
You also can create a python file and then use vim or nano to write the code.
After I write a script in my laptop and I transferred into Pi. How do I know the code I wrote will communicate with the flight controller (Navio2).
2). I tried following link to calibrated ESCs. It did not work for me. I could hear two beeps in the beginning when I connected my battery with my throttle position up. Then after disconnecting my battery I could still the starting two beeps nothing after that. Tried other different methods still no result.
