I’m glad this popped up. I have never used stop & go. Is it so you can PPK ground points? Separate from RTK observations?
Spot on!
Hi Michael,
Sure, you can use Stop & Go for ground points collection in PPK. The only thing different in the workflow from the standard PPK survey is that you need to collect the points in ReachView 3 project. The CSV file from this project will be used to calculate the point coordinates. You’ll get the corrected CSV file at the end of the processing.
It’s really simple to use. Don’t hesitate to check out the Stop & Go with ReachView 3 guide.
