Hi there!
I am a manufacture in quad Copter Controller for Windows using the now Wifi.
To communicate with UDP, it has to send a signal to the ESC.
However, brushless motor does not work.
Perhaps I think that because the calibration has not be set.
Symptom is the same symptoms as the video below.
Calibration was in reference to the following.
Navio2 source code
int main()
PWM pwm;
int sock;
int val;
int errno;
int n;
double inputMax = SERVO_MAX - SERVO_MIN;
double InputData;
double ST;
struct sockaddr_in addr;
char buf[2048];
sock = socket(AF_INET, SOCK_DGRAM, 0);
addr.sin_family = AF_INET;
addr.sin_port = htons(12345);
addr.sin_addr.s_addr = INADDR_ANY;
bind(sock, (struct sockaddr *)&addr, sizeof(addr));
val = 1;
ioctl(sock, FIONBIO, &val);
if (check_apm()) {
return 1;
if (!pwm.init(PWM_OUTPUT) && !pwm.init(PWM_OUTPUT + 1)) {
printf("Output Enable not set. Are you root?\n");
return 0;
pwm.enable(PWM_OUTPUT);
pwm.set_period(PWM_OUTPUT, 50);
while(true)
memset(buf, 0, sizeof(buf));
n = recv(sock, buf, sizeof(buf), 0);
if(n >= 1)
ST = inputMax * atof(buf) + SERVO_MIN;
printf("%lf\n", ST);
pwm.set_duty_cycle(PWM_OUTPUT, ST);
return 0;
