thank you so much for the hint. now i’m trying to find out how to clean my files.
this is what i did after i processed with time frame selected. but if i zoom in there are ireelevant data it’s in there so i’m wondering how can i clean up and just keep the required path as i need from this point?
If its just for the visual part in RTKplot you can use the Time edit in the menu to set wanted timeframe. Also sort out FIX by using Q1 from the drop down menu and change setting in general. This will not affect the .pos file.
For any trim of the .pos you need to use RTKpost
