Every project must be a separate file,to find in the File Manager?
Hi Jan-Olov,
ReachView 3 exports points from each project in a separate CSV file, which you should see in the file manager. If I understand you question wrong, please elaborate on what you’d like to do.
The laptop File Manager found the R3 files!
I would like to enter a few coordinate points into Reach3!
Must it be put in as a file?
Are you talking about multiple base station points for points to be staked out? Points to be staked out should be imported as a CSV file.
So you can not put in single points out in the field?
Only CSV file inport?
You can manually enter them or import them via CSV.
How do you enter manually?
Hi Jan-Olov,
At the moment, it’s only possible to import the CSV file into ReachView 3. This video guide should help you with that:
OK! The video is good,but shows everything to fast, half a second it seems!
Sorry, you can only manually enter the base point.
