Full disclosure–I typically use my Emlid device as a NMEA GNSS device with Survce and expectations made of this software should not directly apply to Emlid’s Flow.
Many data software collector softwares have the ability to export out their raw data in different formats with RW5 being a common format. Survce has the ability to export out your base location if you use their approved hardware (ie. BRX7, etc.). I have included an example below. Note that the “#words words words” are comments that I have added for additional clarity in this post.
#job number and date
JB,NM20230814BRX7 - JLJ(230067),DT08-14-2023,TM19:17:17
#the data collector takes the scale as given from the RTN; we used CANNET for this example
–MO,AD0,UN1,SF1.00000000,EC0,EO0.0,AU0
–SurvPC Version 6.16
–CRD: Alphanumeric
#coordinate system/project along with hardware info
–Projection: CANADA/NAD83/UTM zone 17N
–Equipment: Carlson, BRx7
–Antenna Type: [BRX7 Internal],RA0.0785m,SHMP0.0547m,L10.0701m,L20.0629m,–L1/L2/L5 Internal Antenna
–Localization File: None
–Geoid Separation File: C:\Carlson Projects\Data\Geoids\Canadian_ht2_0.gsb N41°01’00.0" W141°58’59.0" N83°58’58.0" W048°01’03.0"
–Grid Adjustment File: None
–GPS Scale: 1.00000000
–Scale Point not used
–Entered Rover HR: 1.7900 m, Vertical
LS,HR1.8601
#I logged RINEX on the rover so I can PPK if necessary off one of the network bases
–GPS Log File: 230814ROV1230067.bin rover open Carlson,BRx7
–GNSSLOGRCVR,FL230814ROV1230067.bin,SRROVER,RND2041500803050,RMHEMBRx7,RF6.0Aa04a,1.19,0.66.220415A
–GNSSLOGANT,FL230814ROV1230067.bin,AN,AMHEMS631 NONE,LI1000,AG1.790,PA0.070
#this is the setting we have to use to make CANNET work with non-Trimble equipment
–RTK Method: RTCM V3.2, Device: Data Collector Internet, Network: NTRIP caneastvrscmrx
#this is the important bit for you; one can take this info and convert it to find your base point; you could use something like SGSS Tools->Coordinate Converter to do so ( Coordinate Calculator | Simple Geospatial Solutions )
BP,PN1234_BASE_1,LA42.544145257737,LN-81.174052470818,EL224.2120,AG0.0000,PA0.0000,ATAPC,SRROVER,–
–DT08-14-2023
–TM19:17:44
–Entered Base HR: 0.0000 m, Vertical
LS,HR0.0000
#CANNET uses a VRS so I always record it just to know where it is; it changes often which is one of the annoyances of VRS; it doesn’t have a “locked” base station like a standard RTN or one putting out iMAX/MAX solutions
GPS,PN1234,LA42.544145257737,LN-81.174052470818,EL224.212006,–CANNET RTN VRS RTK BASE
–GS,PN1234,N 4751030.8092,E 475954.0038,EL259.6099,–CANNET RTN VRS RTK BASE
LS,HR1.8601
#here we get to work and start taking shots
GPS,PN6000,LA42.544003779713,LN-81.173942781220,EL227.579673,–CC CUTTEE SDW
–GS,PN6000,N 4750987.0815,E 475978.7219,EL261.1179,–CC CUTTEE SDW
G0,2023/08/14 23:27:04,(Average) - Base ID read at rover: 1234
G1,BP1234_BASE_1,PN6000,DX29.46753,DY-28.05602,DZ-29.68381
G2,VX0.00001270,VY0.00006234,VZ0.00004335
G3,XY-0.00000129,XZ-0.00000160,YZ-0.00002951
–GT,PN6000,SW2275,ST170832800,EW2275,ET170843800
–Valid Readings: 11 of 11
–Fixed Readings: 11 of 11
–Nor Min: 4750987.0775 Max: 4750987.0840
–Eas Min: 475978.7206 Max: 475978.7230
–Elv Min: 261.1153 Max: 261.1215
–Nor Avg: 4750987.0815 SD: 0.0020
–Eas Avg: 475978.7219 SD: 0.0007
–Elv Avg: 261.1179 SD: 0.0019
–HRMS Avg: 0.0060 SD: 0.0002 Min: 0.0057 Max: 0.0065
–VRMS Avg: 0.0090 SD: 0.0004 Min: 0.0085 Max: 0.0098
–HDOP Avg: 0.5615 Min: 0.5615 Max: 0.5615
–VDOP Avg: 0.9765 Min: 0.9764 Max: 0.9767
–PDOP Avg: 1.1265 Min: 1.1263 Max: 1.1266
–AGE Avg: 1.0000 Min: 1.0000 Max: 1.0000
–Number of Satellites Avg: 28 Min: 28 Max: 29
–DT08-14-2023
–TM19:27:10
–Calculated GPS Scale: 0.99957168
We later use the data collector to scale things to ground on the fly as we are doing a “flatlander” cadastral survey.
If Flow has a format export option, it might be worth seeing if it has the info in an RW5 export. I don’t know as we also use total stations with most of our work and Flow does not have an option to use that hardware.
To be completely fair, one should not expect that of Emlid, but it makes it so that we use their products with data collection software that does support total stations. I would totally switch if they did as I really enjoy all of Emlid’s products.
