I’m looking for a way to pass a command to M8T GNSS board via reach module, to reconfigure the PPS pulse to 5Hz (pin 3 in M8T).
Some suggestions about the steps and the command to pass?
Best regards,
Thiago Tiedtke dos Reis
Best regards,
For now, I found a “workaround”, soldering an usb connector directly in pins of M8T, and acessing / configuring the M8T via u-center (from ublox)
Offcourse, I accessed the ssh and stopped ReachView to avoid comunicate via UART and stops the USB communication.
Attached a photo of the “workaround”
But, a simplest solution will be appreciated (by command line/script via ssh terminal)
Best regards,
