Hello everyone,
I recently have a Sony QX1 camera that I will use to take photos from ‘Mission planner or QGround control’.
This camera generates a Wi-Fi network to connect the application ‘PlayMemories Mobile’ your connection is by wifi to a mobile device, such as IOS, Android etc.
Looking to be able to fire it from my RPi3, I found ‘Pysony’, an API in Python to use the camera which I managed to shoot with this API.
Now I need to read the status of the pin that performs the camera firing using ‘Mission Planner’ to be able to make a program in python that reads the status of the pin and shoots the camera with the API
My question is, can I read the status of the pin to save it to a variable?
If I understood correctly you set camera trigger to drive your pin high and have a separate Python monitor script that will just check the the pin state (I suppose the better option would be to use poll() in here) and the fire up the API.
