I’m trobuled in read obs obs data.I want to know every numbers means to study gnss?
finally,anyone can introduced some books or thesis about gnss or post processed kinematics?
Hi @qzmp69375 , and welcome to our community forum!
Data records in RINEX .obs files include the following content:
The first line is the epoch. It shows the date and time of the record in yyyymmdd hhmmss format.
In the first column:
The letter shows the satellite system (G for GPS, R for GLONASS, E for Galileo, etc.).
The value is the number of a particular satellite.
Each line contains several variables for the specified satellite. They go in the following order:
C = pseudorange, which is the distance from the receiver antenna to the satellite antenna, including receiver and satellite clock offsets.
L = career phase. It’s the difference between the phase of the receiver oscillator and the signal received from the satellite + the number of cycles at the initial start of the tracking phase.
D = doppler, which stands for a change of frequency due to the Doppler effect. The sign of the value is positive for approaching satellites.
S = signal strength or Signal-to-Noise Ratio (SNR). It’s the value that compares the level of the desired signal to the level of background noise. The great value for L1 frequency starts from 35-40.
