after some time I’m finally ready to fly and use our Navio2 controlled hexacopter and Reach for aerial mapping.
I’m very happy with the first results, although it’s not perfect right now and the camera wasn’t accurately focused. Navio2 and Reach worked very well.
I’m still struggeling with postprocessing the logs from Reach. The solution for the base station has a height drift of more than 1 m during 3 h, that is not great.
To get the best out of the rover I would be very interested in some comments on the antenna placement. How bad are vibrations, should I place the antenna directly above the flight controller to reduce vibrations and acceleration or should I place it further up and away from the possible emi sources?
These are the logs of my frist fligth: emlid.zip (7.7 MB)
Thank you,
Tobias
