I’m trying to integrate a Sony LR1 camera with the Emlid Reach M2 to perform PPK (Post-Processed Kinematic) geotagging.
I understand that the Reach M2 can record camera trigger events through the C1 port, but I’m not sure about the correct wiring and configuration for the Sony LR1.
Here’s what I’d like guidance on:
How to connect the Sony LR1’s exposure signal to the Reach M2 C1 port for accurate timestamp logging.
Whether I need to use an external circuit (like an open-drain pull-up or level converter).
Any specific settings required on the Sony LR1 to output the exposure signal correctly.
Example setup or diagram if available.
My goal is to synchronize each photo with GPS time for precise PPK geotagging.
The Emlid Reach M2/M+ Camera Hot Shoe Adapter wires the flash sync pulse from the camera to the Emlid Reach for precise time stamping of each picture. Necessary for PPK workflow. Designed to work with any camera with hot shoe connector, tested to work with Sony, Canon, and Nikon.
The Sony LR1 does not have a hot shoe output, but it does provide an exposure output.
I’ve read the linked forum thread on “Request for Reference Time Mark Signal — Sony ILX-LR1 Exposure Output Integration”, but it’s still a bit confusing regarding the correct pull-up resistor and wiring.
You’ll need to connect the ground pins of the C1 port and the camera, and the M2 event pin from the C1 port to the camera’s shutter signal pin with the custom cable. If there’s enough voltage above the 3.3V logic level, the pin will read the signal and a time mark will be recorded.
“We haven’t tested the integration with the Sony ILX-LR1 with M2 so is hard to suggest the best setup configuration.
This camera doesn’t have a hotshoe. However, one of our users successfully achieved this integration by using a 20k pull-up resistor and replacing the mechanical shutter with an electronic one.”
For the M2 module, we designed the hot shoe connection as the easiest way to link the module to the camera. Since the Sony LR1 camera lacks a built-in hot shoe connection, a custom setup is necessary. The workaround we suggest is based on user experiences that involve creating a custom setup. However, we don’t have further details about this setup, so I can’t provide additional information at this time.
I am tested the Sony LR1 camera with the Emlid Reach M2 for PPK by connecting the LR1 exposure output to the Reach M2 Timemark pin .
During testing, I captured around 500 photos, but only 58 timemark events were recorded in the Reach M2 logs.
I compared the LR1 exposure→timemark signal with another camera (EDTi) that has a standard hot-shoe output→timemark and works properly.
I observed that the LR1 open-drain pulse width is longer than the EDTi hot-shoe pulse.
I am not sure if this wider pulse is the reason for the missed triggers.
I have a few questions:
How does the Timemark input on the Reach M2 detect triggers? What are the expected voltage levels, edge polarity, and acceptable pulse width range?
can you recommended electronic interface circuit taht we can make the LR1 exposure signal compatible with the Reach M2 Timemark input?
Can an AirPixel AirCommander or similar interface help ensure proper triggering and logging?
Hi @lavlesh.poyarekar, thank you for sharing your project. Since it involves a custom setup, I may not be able to provide detailed guidance, but I answered the question in points below:
The Timemark input on the Reach M2 detects triggers through the central pin of a hot-shoe adapter, which carries 3.3V. When the camera takes a picture, this pin is shorted to ground, causing the voltage to drop to 0V. The M2 records a time mark on this falling edge. Please note that the maximum voltage this pin can safely handle is 3.6V, but 3.3V is well within safe limits.
We have not tested the Reach M2 with a camera that does not use a hot shoe, so I cannot recommend a specific electronic circuit to make the LR1 exposure signal compatible. Hopefully, users who have experience with this custom setup will share their insights.
While I haven’t personally worked with this interface, I see in this thread that some users have attempted to integrate the Reach M2 with Air Pixel and Air Commander. However, I couldn’t find a definitive conclusion on whether their setups were successful.
