Hello,
i have Navio2 on a raspberry pi 3 +b and i am using the latest image that you provide.
This comes with gstreamer v1.14 installed. My goal is to stream video in 4g network through Gstreamer but instead of using in the gstreamer command the raspivid element I would like to use the rpicamsrc element… All people say that it is far superior than raspivid… Furthermore, I would also like to use the SRT protocol for streaming through Gstreamer which is so much faster.
Gstreamer v1.18 includes the raspicam and you dont need to install it manually. SRT has to be built from sources and I was able to do that… But unfortunately I cannot build from sources Gstreamer 1.18… The instructions are too advanced and its so difficult for someone like me without any knowledge and experience on building from sources…
Unfortunately, by using the sudo apt-get install gstreamer1.0 command does not install the latest 1.18… SO i gues the latest available gstreamer version in the repositories is v1.14.
There is a nice guide that i found in github.com https://github.com/PietroAvolio/Building-Gstreamer-Raspberry-Pi-With-SRT-Support . One guy wrote a guide on how to install raspicam, SRT and then how to update gstreamer by executing a script… Unfortunately, this guide does not work anymore. It worked for version 1.16 of gstreamer, but v1.16 has a bug and it does not allow to use the SRT protocol…
Could you please guide me with simple 1, 2, 3 … steps the commands that I need to execute in order to install gstreamer v1.18 ? All attempts I have tried to do this failed because i dont have any knowledge on that. I haven’t found any useful help on Gstreamer forums… All expert guys there seem so busy and snob to exlpain very simple steps for novice users.
Ideally, it would be great if in the image you provide you could include Gstreamer v1.18… v1.14 is quite old…
Thanks a lot in advance for your help…
