I am using Rpi 3 + NAVIO2 (emlid-raspbian-20170922.img.xz)
I have alreay made some changes to the system get intwifi0 as AP using:
I have inserted TP-Link TL-WN722N(EU) Ver 2.0 wifi dongle expecting it to connect to the network that I have spcified in wpa_supplicant file. That config worked with intwifi0 before I changed it to be access point.
Ifconfig shows,
pi@navio:~ $ ifconfig
enxb827eb05e185: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether b8:27:eb:05:e1:85 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
intwifi0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 10.10.10.10 netmask 255.255.255.0 broadcast 10.10.10.255
inet6 fe80::27b3:a375:e5d6:7bb0 prefixlen 64 scopeid 0x20<link>
ether b8:27:eb:50:b4:d0 txqueuelen 1000 (Ethernet)
RX packets 1421 bytes 118234 (115.4 KiB)
RX errors 0 dropped 2 overruns 0 frame 0
TX packets 749 bytes 77276 (75.4 KiB)
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1 (Local Loopback)
RX packets 1384 bytes 123326 (120.4 KiB)
TX packets 1384 bytes 123326 (120.4 KiB)
wlxd46e0e028dcf: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether d4:6e:0e:02:8d:cf txqueuelen 1000 (Ethernet)
iwconfig shows,
pi@navio:~ $ iwconfig
intwifi0 IEEE 802.11 Mode:Master Tx-Power=31 dBm
Retry short limit:7 RTS thr:off Fragment thr:off
Power Management:on
enxb827eb05e185 no wireless extensions.
lo no wireless extensions.
wlxd46e0e028dcf unassociated Nickname:"<WIFI@REALTEK>"
Mode:Auto Frequency=2.412 GHz Access Point: Not-Associated
Sensitivity:0/0
Retry:off RTS thr:off Fragment thr:off
Power Management:off
Link Quality:0 Signal level:0 Noise level:0
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:0 Missed beacon:0
lsusb shows,
pi@navio:~ $ lsusb
Bus 001 Device 005: ID 0e8f:00a7 GreenAsia Inc.
Bus 001 Device 004: ID 2357:010c
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp. SMC9514 Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
My interfaces file,
pi@navio:~ $ cat /etc/network/interfaces
# interfaces(5) file used by ifup(8) and ifdown(8)
# Please note that this file is written to be used with dhcpcd
# For static IP, consult /etc/dhcpcd.conf and 'man dhcpcd.conf'
# Include files from /etc/network/interfaces.d:
source-directory /etc/network/interfaces.d
auto lo
iface lo inet loopback
iface eth0 inet manual
#allow-hotplug intwifi0
#iface intwifi0 inet manual
# wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
allow-hotplug wlan0
iface wlan0 inet manual
allow-hotplug wlan1
iface wlan1 inet manual
