FisherLong
(Fisher Long)
1
hi there ,i’d like to record the raw gnss data for post-processing- UAV photogrammetry, I set the recording rate at 14hz(the screenshot )
but when i stop ,and get the rinex data .i found that the default recording rate is 0.1s(10hz):
Did i set the wrong parameters?
bide
2
Maybe you forgot to click “Save” before starting the rover?
If you refresh the ReachView config page in your browser, does it still say 14Hz?
FisherLong
(Fisher Long)
3
yes if i do not click save and then refresh the page it change to GPS 10hz.
thank you for your suggest , i have a try immediately.
FisherLong
(Fisher Long)
4
thanks for your suggestion , i’ve got the 14hz result after click “save”.
