Is it possible in Flow360 to duplicate a project, including all its data points and the localized coordinate system?
I have explored various export/import formats, but none of them seems to keep the localization information.
@kbjshop , I have not tried it, but there is an option in Flow360 to save the current Coordinate System (which I assume would be the localised one as it would have a (1) at the end. Click on the three meatballs next to it (should be in the right pane when you first open a project), then click “Save to My CS”. Perhaps give it a more descriptive name though as it would then be project specific.
I assume from there, you can use it as a Coordinate System when you create a new project file. When picking the CS, it should be then under “Use Custom”.
It would be good if when setting up a new project, that you could ask it to grab it from another project though.
Joel
Hi @kbjshop,
Sorry for the radio silence here.
I agree with @joelbladen. You can save your coordinate systems determined by localization and use them in new projects. We’ve written a guide on how to do this.
For now, there is no straightforward way to duplicate the project including its localization. As a workaround, you can follow the steps outlined below:
Thank you for your answers. It has taken me a long time to circle back to this one! Grateful for the help.
Hi @kbjshop,
Did I understand it right that you were able to create a new project using parameters from localization?
