I would like to disable the onboard MS5611 barometer. The problem is that 0x76 and 0x77 i2c addresses are already used on my other sensors connected to the board. Is it possible to change to some other address or disable it?
- Grega
I am afraid that you will need to desolder the sensor to achieve that.
Is it possible to just cut some connection on board?
Hi everyone !
Even if the first posts are old, I am really interested in this question because my barometer seems dead. I would like maybe to use another one to allow the data from other sensors to be sent to Mission Planner (thing that I am not able to do anymore).
To disable the barometer seems to be a good option. Did you succeed in finally ?
If anyone can help i really appreciate it.
Thank you !
Julie
