How to delete specific points in an Emlid Flow project
I need to delete several points in an Emlid Flow project to clean it up a bit but I can’t find a way to do that short of exporting the data to a csv, editing the csv file, and then importing back into Flow. What am I missing? Thanks
Select the point and then slide up from the bottom to show it’s properties and you can delete it if desired.
I think he means select multiple points at once.
No multiple select in Flow yet that I know of. But is available in Flow360
You’re both correct. I hadn’t been scrolling down far enough into the properties screen to see the “Delete” button so I was confused on that point. However, I was also wondering about a means to select multiple points at once to delete at the same time; like deleting photos on my phone. Thanks.
Something as minor as that should be an immediate hot fix.
This would also be a great opportunity to create a staking list and if the software was really smart it would order the staking in the most efficient path.
Hi @SteveB,
As @dpitman mentioned, you can currently select multiple points in Emlid Flow 360 and delete individual points by selecting and clicking “delete” in Emlid Flow.
Regarding the ability to select and delete multiple points at once, like deleting photos on a phone. I’ll raise this as a feature request and pass it along to our development team for future consideration.
Hi @michaelL,
I will add your idea as a feature request as well so our development team can consider it for future updates.
