I have just started using a trial license of Survey plan for Emlid Flow 8.0 on an Android 7.1.1 phone, and it works great
I can fine import and create code libraries in Emlid Flow 360. But how do I delete a code library? I can’t seem to fine an option for this on either Emlid Flow 360 or in the Emlid Flow app on the phone.
Yes. Delete and/or rename Code Library would be great. Edit is needed at the very least.
I started with a basic library with 15 codes. Later I created a .csv with all of our 75+ codes and planned to update the same library but couldn’t overwrite or delete it. I ended up deleting the original 15 codes from the new .csv and then the import was received. I just couldn’t edit them if I got it wrong the first time. So all good.
