how to create static points, I am from chile greetings, this has been a chaos
Place the rover rod over your point, ensure you have static rtk settings enabled, wait for fix, read your value or start a survey and get an average value over time.
what are the static rtk settings
It always helps to read the fine manual
Static - an assumption is made that Reach is static. Constraining the system helps to resolve ambiguities faster as well as produce measurements with higher precision.
from a reference station which of these two would serve me?
Fix-and-hold: after first ambiguity fix hold them constrained. Fix is more stable, but in case first initialization was not correct it will take longer to recover and initialize correctly. You can think of it as if Fix had inertia.
Continuous: ambiguities are resolved epoch by epoch. Less stable, but no risk of holding a false fix.
In real-life conditions on moving platform Fix-and-hold provides better overall performance.
Do you want to collect a point in RTK or post-process raw data from Reach to get point coordinates?
to carry out a post process later
May I ask you to share your Reach Simple system report? I can check it to make sure your configurations are appropriate.
details=“Simple system report”]
app version: 2.16.1-r0
'wifi_status, interface: wlan0':
- wifi_mode: ap
- access_point:
band: bg
channel: 1
password: null
ip: 192.168.42.1
is_added: true
is_connected: true
mac_address: 8C:F7:10:18:32:E0
security: wpa-psk
ssid: Base_:D3:3A
uuid: e535f3e0-c489-4dad-be79-369b02ee2b69
base mode:
base coordinates:
accumulation: '5'
antenna offset:
east: '0'
north: '0'
up: '1.11'
coordinates:
- '-19.9944838494'
- '-69.7715816429'
- '1145.208'
format: llh
mode: manual
output:
enabled: true
format: rtcm3
path: lora
type: lora
rtcm3 messages:
'1002':
enabled: true
frequency: '1'
'1006':
enabled: true
frequency: '0.1'
'1008':
enabled: false
frequency: '1'
'1010':
enabled: true
frequency: '1'
'1019':
enabled: false
frequency: '1'
'1020':
enabled: false
frequency: '1'
'1097':
enabled: true
frequency: '1'
'1107':
enabled: false
frequency: '1'
'1117':
enabled: false
frequency: '1'
'1127':
enabled: false
frequency: '1'
gps:
enabled: false
frequency: '1'
qzss:
enabled: false
frequency: '1'
bluetooth:
discoverable: true
enabled: true
pin: '***'
correction input:
input2:
enabled: true
format: rtcm3
path: ttyMFD2:38400:8:n:1:off
send position to base: 'off'
type: serial
input3:
enabled: false
format: rtcm3
path: :9028
type: tcpsvr
logging:
base:
format: RTCM3
started: false
version: null
correction:
format: RTCM3
started: true
version: null
interval: 24
overwrite: true
raw:
format: RINEX
started: false
version: '3.03'
solution:
format: XYZ
started: false
version: null
lora:
air rate: '9.11'
frequency: 900000
output power: '12'
position output:
output1:
enabled: false
format: nmea
path: bluetooth
type: bluetooth
output2:
enabled: false
format: llh
path: :9001
type: tcpsvr
output3:
enabled: true
format: xyz
path: :2014
type: tcpsvr
output4:
enabled: true
format: llh_ext
path: :2015
type: tcpsvr
rtk settings:
elevation mask angle: '15'
glonass ar mode: 'on'
gps ar mode: fix-and-hold
max horizontal acceleration: '1'
max vertical acceleration: '1'
positioning mode: static
positioning systems:
compass: false
galileo: true
glonass: true
gps: true
qzs: true
qzss: true
sbas: true
snr mask: '35'
update rate: '5'
[/details]
Thanks! It looks fine.
I’ve noticed that you didn’t enable raw data logging. Don’t forget to turn it on before you start to collect the point.
So you need:
- Set up the unit on the point you want to collect;
- Enable raw data logging;
- Record log on this point;
- Export log from Reach on your laptop/PC;
- Get the log from the reference station;
- Post-process logs.
Thank you very much Tatiana.
the raw data of emlid can be transformed to rinex that can be used in another post-process program
Sure, you can convert raw data to RINEX using RTKConv and then use it in any software for post-processing.
You also can start raw data logging in RINEX format in ReachView.
