Hi can anyone help me with the solution? I have reach M2 ppk file in .ubx format and rinex file from base station to correct. I want to convert the position in latitude longitude and altitude as .csv file for georeferencing.
Hi @sweta.kandwal,
Welcome to the community!
If I understand correctly, you’d like to do Stop&Go with your files to get the corrected points in the CSV. If so, let’s go through the following steps:
- Convert your UBX file to RINEX in Emlid Studio.
- With the converted file and the base’s RINEX files, you can already do the Stop&Go following this guide.
I hope this helps. But also feel free to email your files to support@emlid.com, and I’ll check the post-processing for you. Thanks, and please let me know how it goes!
thank you for your response. Yes, I want a corrected csv file for which im doing Stop&Go with the files but what I don’t understand here is that, what should be the input for project from emlid flow(csv)? How to generate csv from emlid flow? I need csv file of corrected co-ordinate for georeferencing.
Hi @sweta.kandwal,
You can export your project in CSV format from Emlid Flow or Emlid Flow 360.
These points have a SINGLE solution as they were collected without any corrections. With the Stop&Go processing, the goal is to improve their accuracy, and the new points with corrected coordinates will be saved in a new CSV file.
