I plan to switch to Emlid GNSS receivers but before I place the order, I was wondering, what is the number of digits for the latitude and longitude in the NMEA GGA Stream?
Usually, in RTK we configure our receivers to get at least 7 digits in order to get sub-centimeter resolution.
Thank you.
Hi @rreignier,
NMEA stream from Reach receivers consists of several messages. GNGGA message has 7 decimal places in the latitude and longitude values.
Reach receivers don’t require this configuration to establish an RTK-link. To obtain a centimeter-level accuracy, you need to set up the corrections output/input in the ReachView app. This will automatically calculate the Fix solution if all the placement requirements are met. Please check the Base and Rover setup guide for more details.
Hi @liudmila.slepova
Thank you for the welcoming ![:slight_smile: :slight_smile:](https://community.emlid.com/images/emoji/apple/slight_smile.png?v=12)
Great, that all I need.
Thank you.
