So I followed the instructions on how to post process the data, and it gets to the point where you can view everything. But now I’m not sure what I actually do to correct the points that I picked up.
When I was doing the survey, I very rarely got a ‘fix’, though I did have float the entire time. So I sat on every GCP for a 1 minute observation. Quite a bit of ‘movement’ even though the rover was using a bipod the entire time so it was perfectly still.
The base station was on a tripod and set to average a point with a 10 minute observation. I had strong link to the base the entire time. I was only about 300m away during the survey.
I also shot an ASCM marker as a check in and check out.
Here is the raw logs + what was post processed according to the guide (as best as I could figure).
That’s fine, I’ve normally been able to get a fix with the settings I was using since I followed those two links you put down.
That still doesn’t help how you correct the points after post processing. I mean that’s the whole point right? You can’t get a good fix at the time so you recalculate after the fact.
I think you have to elaborate on what you mean by “correct picked up points” ?
Do you mean how do you get your 1-minute obs points out of the raw-file ?
Yes. I want to take the shots that I have collected (GCP’s) and recalculate what I’ve done based on the post processing. Hopefully to increase the accuracy of the GCP’s.
