The docs refer to the settings page to control the logs are rolled. The log pages allows me to choose which data to log, but I can’t find anywhere to set the frequency of the logging.
thanks,
steve
thanks,
steve
You find it here
https://docs.emlid.com/reachm-plus/common/reachview/rtk-settings/#gnss-selection
This particular setting will affect both raw.ubx and rinex logging. The rest of the settings applies to rinex only
In RTK settings you can change the update rates. Go to GNSS selection and below that is uodate rate were you can change to 1hz,5hz,10hz or 14 hz
