Hotspot / Wifi issue
Hi @malcolmdavidge,
May I ask you to click on the “Wi-Fi has no Internet access Tap for options” pop up notification? There should be a possibility to keep your phone connected to the Reach hotspot even if there is no Internet connection.
Also, it looks like the device is stuck on the Time Sync stage as the green LED remains off. There are 2 ways to go through it:
  1. Connect Reach to the Wi-Fi network with Internet access once you’ll be able to access it
  2. If you keep the device in hotspot mode, connect a GNSS antenna and provide it with sky view (you can just place it near the window, it should work)
