My REACH M+ is making a hotpot which i am connecting to OK, but reachview does not ‘see’ the unit and i cannot connect via a browser on the PC either.
The WiFi network which was used to set it up initially has changed now so i cant use that.
I think i setup my phone hotspot as a recognised network, but this is not registering with the reach either.
That’s why I asked about the mobile data. Everything is on in those images. There’s no airplane and it clearly shows 4G. Airplane mode isn’t necessary, just mobile data had to be off in my case.
I figured as much. Doesn’t seem like something we should have to do. I guess I need to get another device so I don’t miss anything whilst surveying. Actually I did find a carriage for my iPad Mini so I will probably start using it as soon as it catches up in development. Happens to be the same one I use for my Topcon FC-5000.
May I ask you to click on the “Wi-Fi has no Internet access Tap for options” pop up notification? There should be a possibility to keep your phone connected to the Reach hotspot even if there is no Internet connection.
Also, it looks like the device is stuck on the Time Sync stage as the green LED remains off. There are 2 ways to go through it:
Connect Reach to the Wi-Fi network with Internet access once you’ll be able to access it
If you keep the device in hotspot mode, connect a GNSS antenna and provide it with sky view (you can just place it near the window, it should work)
